Well I have ohmed out the L&R bank power feed to all the injectors, they were 3.2 or 3.3 ohms. The range is 2.8 to 3.6 ohms
L&R bank power feed to IDM ground circuit it was open.
L&R bank power feed to injector ground shield it was open.
So at this point I would think it is the IDM?
Thanks RB
Well I finally bought a new IDM and installed it the other nite. Started the truck and it runs good again.
Thanks to all that helped me with problem I certainly could not have done this fix without your help.
Thanks RB
I used a meter on my UVCH while truck was running and cant see the 110v as it is isolated to ground but when using meter across the coil output I could only see the pulses but not measure it. an oscilloscope could be used but not many have one of those. I might go dig mine out just for fun some night
