vs identification
vs identification
A friend gave us an old flathead he had in his yard as he liked them back in the day and thought we could use it for the project.
We are targeting a different engine but maybe this one.
He could not identify it and thought it maybe a truck version.
We never worked on any so we are clueless.
Here are some photos to review and if there is a place for casting or forging marks please advise.
looks like it was port covered before storage but it seemed stuck but we did not try too much.
Probably 'non-foulers' commonly used on worn engines that pumped so much excessive oil into the cylinders that they fouled the plugs quickly. They shroud the end of spark plug and reduce the amount of oil contamination while also reducing the amount of spark to ignite the fuel charge. Basically a band-aid on a gun-shot wound and the first indication of a worn out engine.
As others have stated that is a 1932-1936 motor. The intake is 34 or later. Depending on the condition of the block and what block it is it may or may not be that desirable. The block can be identified by the oil pan rail, area between the water inlets and distributor, and the spacing of the main cap bolts. For details see the big block identification thread we did over on the Ford Barn:
Engine block I.D. pictures - The Ford Barn
56panelford
06-29-2019 08:18 AM
ihcc104
08-21-2016 08:58 AM
