Radiator shroud
Radiator shroud
I have a 64 with this radiator. I am looking for a shroud that will fit this radiator. I have seen some threads that a later year shroud bolts right up but it is for the radiator with the smaller tank. Will the shroud work for this rad as well? I guess I need to say this truck has the 292 with HD cooling. Thanks for your responses.
From pic's it's difficult to me to determine if the radiator to support is an original, or standard configuration; may consider measuring then browse and compare measurements with various sources for a shroud that will work for your application; i.e., Ebay, DC, etc.
Carolina Classics catalog has the fan shrould listed in their catalog; 66 thru 79.
Mac's catalog list fan shrouds later model Ford trucks; 68 thru 79?
D3TZ-8146-C (replaced C8TZ-8146-K) .. Fan Shroud / Marked on upper left corner: C8TA-8146-S or D3TA-8146-DA / Reproduced
Use with standard, xtra cooling and A/C radiators that measure no more than 26 7/32" wide x 19 3/4" high.
Original applications: 1968/76 F100/350 360/390.
1983: I installed this fan shroud on my 1965 F100 352, it fit like it was made for it. I've mentioned this shroud many times in this forum.
A member with a 1964 F100 292 bought one (from Carpenter), said it "fit like a glove."
Carpenter has this shroud listed (along with the specs and this Ford part number) in his 1967/79 truck repro parts catalog: $119.00.
Note: There is another shroud that was ONLY used on 1967/76 F100/350's with the Super Cooling Radiator that measures 26 1/4" wide by 24 11/16" high.
The radiator supports used with this fan shroud are different, as they have a larger opening radius.
C7TZ-8146-B .. Fan Shroud-Use with Super Cooling Radiator only / Marked on upper left corner: C7TA-H or D2TA-HA or D3TA-JA / Reproduced
Carpenter also has this listed in his 1967/79 catalog with the specs and Ford part number: $119.00.
Normally I don't bother arguing, but when my truck came to me it had a very chewed up fiberglass or some kind of fiber fan shroud on my radiator. I did not get a picture but it was there and fell apart when it was touched... You sure there wasn't any from the factory? Was it because I had a F350/292? I had that same radiator that the OP posted.
The only fan shroud listed is C3TZ-8146-K = 1964 F350 223/292 with DRW (Dual Rear Wheels) & F500/700 & F600 with 262 I-6.
So when I said 'these trucks' I meant F100/250 & F350 with SRW (Single Rear Wheels).
red-bulli-69
09-13-2018 11:46 PM
columbia1spring
08-12-2017 06:49 PM
Kelley11
05-22-2015 01:54 PM
