Lowering EGT
Lowering EGT
What besides a 4" exhaust can I do to lower EGT? When I tow with my tow tune the EGT gets high on long steep pulls. Would like to be able to use it with the tune because there is more power and it pulls nicer, but I want to lower my EGT. I have a 4" flo pro system coming. What else can I do? Would a new intercooler make much of a difference? Already have an S&B cold intake and Banks Hi Ram.
When towing up a steep grade it is usually better on these trucks to keep the rpms pretty high 2500-3000. Much below that and is going to start lugging and your EGT will climb. At that point you need to make it downshift. You can get it to downshift if you let of the pedal for a second and then press it back down. Rpms will go back up and you're good.
The Ford stock is also a cold air intake. But that is not her or there.
Have not done it yet but water/methanol injection. The control system
even has it's own little brain.
Also you should be watching more than just EGTs. To get the PCM to
defuel then you have more than just the EGTs getting up in numbers.
Have you also tried the T/H to help keep the RPMs up?
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
I had the same problem and went with the snow water methanol Stage 1 system. I just had to slowly turn the water up to get it where the IAT2 temps are around 100 degrees. That keeps the EGT's at about 1200 pulling a steep long grade. Those small tanks didn't last for nothing. I had to end up putting a 50 gallon water tank in the bed. I just run straight water because the methanol stuff gets pricey. It's supposed to give you an extra 40 horsepower on water alone and I do feel a slight power increase but of coarse when the fan is at 100 percent you lose all that. I tow heavy, so I decided to put it in.
Sean <BR>
6.0L Tech Folder
You know that you can use the blue window cleaner that is only water and methanol?
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
If he were up north then is would be more likely to find it in a store.
That or a drive up to Big Bear if he is down that direction.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
