Tire size question
Received 4,135 Likes
on
on
on
on
Same here, I just want to get it on the road.
on
Yes, with a 30" tire at 60 mph with a 4.10:1 rear axle and an overdrive transmission (4th gear .70:1) you should turn 1929 rpm. That is pretty good as it keeps the low end grunt and gives lower noise and better fuel economy at higher speed.
Tire Height cross reference: https://tiresize.com/height-chart/
Speed Calculator: Tire Size, RPM, Speed, and Differential Ratio Calculator
nlemerise
01-10-2009 08:24 PM
