Both Calipers or Just the Bad one ?
2006 250SD 4x4 only 79k miles
Had the lower piston on the right front caliper freeze on the way home. Fortunately, I wasn't too far from home so it didn't eat the pad down to the metal.
SO, Should I replace both calipers or just the bad one. Of course I will replace all the front pads...
I had my right rear caliper freeze and replaced it. Noticed it after I stopped truck and could smell it right away stepping out of truck. Just replaced that one but 6 months later the left rear did the same. Could have just been coincidence but who knows. By the way, when you replace the caliper it is recommended you replace the soft brake line that attaches to the caliper too.
2005 Ford F250 Crew Cab 5.4l 3 valve
On the Fronts.. it is Always a good idea to replace both...
both started with the same mileage. or other one CAN go bad Soon.
and second... the old own could be dragging slightly... and can cause one side to PULL under hard braking.... NOT even pressure .. one new, one NOT>
besides,, you need to bleed the brakes,, will the other bleeders move.. not rusted in place.
*** check the rubber brake hoses Closely *** 10 years old.. may start cracking.
43 years as an auto/truck mechanic.
Yes, I have been doing brakes before Disc Brakes became common on cars/trucks.
