Low idle
Low idle
I replaced a bbk 65mm throttle body with the stock unit (bbk part was defective) and now with the stock tb I have a really low idle. When I come to a stop idle drops to 750 then 720 then 680 and almost sounds like it's going to die but once gas is applied runs fine. I also had the IAC valve replaced with a new motor craft part, would it be possible the IAC is bad as well? Before I replaced the IAC and stock tb truck ran perfect.
Whoever put on the aftermarket throttle body might have done other mods as well.
Also, did you remove the battery cable and allow it to relearn idle?
Also, maybe you left something unplugged. I've done that with the air temp sensor a time or two.
And maybe you left a vacuum line unplugged or accidentally knocked one loose.
Lots of simple stuff you could double check.
So my idle problem was a loose throttle cable coupled with where the bracket lined up with the linkage, Mechanic adjusted it and now idles between 720 - 750, also replaced all the spark plugs (all 10 were toast) also replaced PCV (also toast) and replaced the battery.
So I now noticed that the truck when it stumbles and goes quite for a second happens when coasting to a full stop when it goes from 2nd to 1st it sometimes drops 150 rpm then balances out, also happens very slightly when it goes 3rd to 2nd.
Would this be a torque converter/trans problem? My trans has been heading downhill for the last 6 months, loss of power going up hills, can hear the clutch spinning when hitting the gas uphill and it pops between 1st to 2nd shooting me forward most take offs from a full stop.
Anthonynoble
08-24-2016 04:13 PM
