Cannot get spark plug socket to seat on some plugs
Old 05-31-2016, 02:55 PM
dnadave's Avatar
dnadave
dnadave is offline
7th Gear
I was able to remove 4 of the 8 plugs on my 2006 5.4l 3V. The other four, I cannot get the socket to completely set on the plug. The socket will barely slip over the top of the hex pattern, but not enough to bite.
Anyone else encounter this problem, and if so, what did you do to remedy it?
Dave H
Old 06-01-2016, 06:07 AM
JWA's Avatar
JWA
JWA is offline
Received 1,394 Likes on 1,103 Posts
Typically there will be something inside the plug well preventing the socket from fully seating on the plug wrench flats. If you can see inside the wells look for accumulated dirt or debris, we've even seen a small washer down inside that was a real bear to remove.
I'm assuming the socket is dedicated to removing your plugs, a "specialty tool" ?
Old 06-01-2016, 12:22 PM
dnadave's Avatar
dnadave
dnadave is offline
7th Gear
I'm using this tool:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You lose a little bit of leverage with the swivel, but it's nice to have for some of the rear plugs.
I thought about debris, and I admit I haven't had a flashlight on any of the wells since it was raining when I did this, but it felt more like something all the way around the plug than on just one side. Of course, this could be due to the insert in the socket that protects the plug.
I'll run a small screwdriver around the plug to loosen things up and see what shows up in my shop vac afterward.
Old 06-02-2016, 06:18 AM
JWA's Avatar
JWA
JWA is offline
That socket and extension is fine for this chore---its not like we're busting lug nuts loose with a 3/8" ratchet.
Cleaning the plug holes and making sure the socket insert isn't the interference should get the other plugs loose too.
Let us know what you find------could be helpful to others at some point.
Old 06-05-2016, 09:27 PM
sinkorswim's Avatar
sinkorswim
sinkorswim is offline
4th Gear
I've seen where someone has tapped new threads into the block to insert an adapter for the plug to thread into (to prevent future problems with plugs blowing out). The adapter piece was a different size than 5/8". Try some different sizes of sockets, I can't remember what size worked but if that's the issue, it's an easy fix.
ugltrk
Aerostar
13
01-10-2018 05:03 PM
SoCalAngler
Modular V10 (6.8l)
33
06-13-2017 12:43 AM
bass-n-fire
1997 - 2003 F150
04-05-2017 10:22 PM
sfc2001
1997-2006 Expedition & Navigator
44
07-10-2011 07:14 PM
griz4718
1983 - 2012 Ranger & B-Series
02-16-2005 08:06 AM
Quick Reply: Cannot get spark plug socket to seat on some plugs
