1990 Fuel injection limits
Guys,
I was lucky enough to find my first truck. A 1990 F-150. this truck will never leave my sight again.
The motor is toast. Which depending on how you look at it can be a good thing. Because it is the original motor and it was my first truck I plan on keep the stock injection system BUT I would like to rebuild the motor with some better touches. Cam, Heads ect. How much can the stock fuel injection system handle? Can the stock fuel injection system handle a cam, headers, heads????
Just curious as to what you guys have pulled off.
I don;t want to make the truck a full mod....just make it run better then it used to back 25 years ago when I first had it!
on
The stock 19lb injectors will technically support 275-300hp depending upon how much abuse you subject them to, the bigger limitation will be the SD EFI control system which will limit your cam choices to pretty mild choices, yes you can throw more lift and duration at it but the total combo must still produce a strong and stable idle and vacuum as that is what fueling is based upon.
Normally I would.
But it is the original motor that drove me around in when I was a kid. So I am keeping it for sentimental reasons. The 302.....she needs to stay.
What if i used high output injectors in the fuel system? Would the stock fuel pump keep up with it? Buying a higher volume pump i would do.
The different cam manufactures list cams that are computer friendly. I actually talked to the techs at Crane at the time and got there recommended cam for my efi 460. And I am happy with it. Your only other choice is to go with a mustang MAF conversion which would widen your choices for cams
on
No that won't work, the basic principle of an EFI system is that it receives feedback from the sensors and constantly makes adjustments to fuel and timing to keep the engine operating as close to optimal all the time. To accomplish this the system must retain all the components the computer is programmed to work with including the injectors, so you can't just throw bigger injectors and a bigger fuel pump at it without reprogramming the computer.
n4ynu1010
17
01-25-2019 09:00 AM
edognight
10-25-2016 01:03 PM
Henry Ford the 8th
08-24-2011 07:17 AM
Mr_Woodrow
04-23-2007 08:37 PM
