oil filter base 5.4 rear
Well have a 5.4 2004 early, as registered as 03. The oil filter base is in left rear position on block. It seams to be leaking out just above filter seal. This truck was a factory starch plant truck so its all corroded don't want to remove to fix. Shure it would not survive. Is there a gasket under the tin shield and can you just leave off shield. As I said its a town bomber to dump and back.
Also there is a electric buzz sound in cab when and after running engine and every once in a while out of the blue. Is there a power up relay for ecm that would make this sound I know its not normal. Will drive you crazy if you have to drive any distance across town never stops. Not a solid buzz its like on off on.
Just starting to fix so its useable. Have to replace rear left spring also. Will never look good beat up bad.
its a f-250 8501-9000lb gvwr vin says a 04 the sticker in door says 8-03 mfd.
tumbleweed1awk
03-25-2013 04:42 PM
