Why does my truck sit cockeyed?
While I had my truck backed into the garage this past weekend for front brake work, I noticed (while walking back from the mailbox) that it seemed to be sitting at an angle. I pulled out a tape measure and sure enough, measuring from the (presumably) level floor to a couple of different points on the front of the truck, it seems to sit about 1/2" higher on the driver's side than it does on the passenger's.
Is this normal, perhaps to account for the weight of a driver? Or is my truck wonky?
Could be those old, tired, saggy springs. Might measure the coils and see if one is compressing more than the other.
Another thing to look at (since you measured body height) is the old, cracked, squished body mount rubber.
Also, check your tire sizes and inflation pressure. My truck had different tire sizes on front when I bought it. Sometimes people just find any old tire and throw it on without making sure it's the same size. Tire size and proper rotation is extra important on 4x4 trucks.
What happens is that having toe-in means that as the truck moves forward the tires are trying to move closer together. The TTB suspension allows this to happen if the suspension extends a little. This also causes the camber to change, tipping the tops of the tires out a little. But no one notices this because driving forward is normal, so the alignment is set to be right when the truck drives forward.
But when the truck backs up the opposite happens. Toe-in makes the tires want to spread farther apart as the truck backs up, so the suspension compresses and the top of the tires lean in.
