Lifting higher
Lifting higher
Hey guys I currently have a 4 inch bds all spring kit with dual front shocks on my 03 6.0 and I'm wanting to go higher
I've been considering adding the icon 4.5 inch hanger system but I'm not sure if it has the right components for 8.5 inches of total lift
Any advice or help would be greatly appreciated
Unless you know what you are doing with driveline and suspension geometry you will be in for a mess. You might be in for either a high angle from driveshaft or t-case index ring. At minimum you need to address the driveshaft angles and get all of that in check. If you know how to do it there's just some work ahead. If not you'll have some money flowing ahead.
1BADRIDE
01-02-2014 09:53 PM
