Lift kit ?
Old Jan 19, 2007 | 10:13 PM
99powerstrokeSD's Avatar
99powerstrokeSD
Lift kit ?
I am in the process of picking out the right lift kit for my 99 SD. Keep in mind that I will be installing this kit myself. I am going to get a 3 - 6 inch lift. Whicj kit do I need. Some come with pitman arms others come with sway bar links, others come with new shocks and others do not. Some also come with new springs. Help me sort all of this crap out! Any advise on what parts are needed and which parts are not.
Old Jan 19, 2007 | 11:21 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Do you want to keep your same ride you have now? If you want to do that, you can use a spring hanger system to extend the mounting points for the springs down, and keep the same ones. Donahoe makes a 4.5" spring hanger kit and 5" block for a nice 4.5" lift. Couple that with a set of Bilsteins and you have a great ride. That and a leveling kit is what i had on my truck, but i had to take it off because it's illegal in MD. If you are interested PM me. However Yes most "kits" include everything you need to do the install. You can do a spring kit, most spring kits in that range are 4 or 6". I think that the worst ride has to be Procomp, and the best is by far, Deaver springs marketed by Donahoe Racing. DR's stuff is over-the-top-good, it is more expensive than most of the stuff out there, but it is by far the best in my opinion. What tire size do you want to run?
Old Jan 19, 2007 | 11:34 PM
travis dasher's Avatar
travis dasher
Hey Strokin, You had a lift and a level kit on your truck.
I have been wanting to do the same, did you have to get longer shocks. It would seem I would have to but I have been told otherwise.
Old Jan 19, 2007 | 11:37 PM
PowerstrokeJunkie
Yes my lift kit is in the classifieds section, or PM me. The shocks are included, and they are capable for 4-6" lift. Bilstein 5100. I am running the stock-height bilsteins now.
Old Jan 19, 2007 | 11:39 PM
bigtorque's Avatar
bigtorque
i put longer shocks on my 4 in. kit.
your really pushing the stock shocks with a 4 in. there is almost no extension on them at that point.
a good set of bilstien 5150 would do it.
Old Jan 19, 2007 | 11:43 PM
bigtorque's Avatar
bigtorque
donahoe racing is the only way to go
the 4.5 hanger kit would be good, though i hear instalation isnt as easy as bolting on a new set of leafs. most of donahoes kits come with bilstein shocks, adjustable pan rod bar (pain in the a$$ to take off) dropped steering arm and dropped sway bar links, its a killer kit
Old Jan 19, 2007 | 11:44 PM
travis dasher
I have a 4 inch lift with shocks. What I was asking is if I put a 2.5" leveling kit on would I have to get a longer shock? Sorry I didnt clarify its been a long day
Old Jan 19, 2007 | 11:46 PM
bigtorque's Avatar
bigtorque
are they the stock length, in they are for the 4 to 6 in. lift, they should work fine.
Old Jan 19, 2007 | 11:51 PM
travis dasher
I dont think they are the same length as the stock ones. I think they are a little bit longer. I do some offroading but nothing crazy. I just want it to sit a little taller.
Old Jan 19, 2007 | 11:57 PM
bigtorque's Avatar
bigtorque
well, take some tape and mark the shock shaft, then jack up the front untill they bottow out, and that should tell you if your lev. kit will work.
Old Jan 19, 2007 | 11:58 PM
bigtorque's Avatar
bigtorque
meant to add measure the distance between the tape and the shock tube.
Old Jan 20, 2007 | 12:00 AM
travis dasher
Thanks Bigtorque and Strokin_it7.3.
Didnt mean to hijack your thread 99powerstrokeSD.
Old Jan 20, 2007 | 12:08 AM
PowerstrokeJunkie
Travis Dasher, do you have a 4" spring lift? If so, a 2.5" leveling kit will not work, unless it is the undesired "add-a-leaf" style which will still be a pain. However the 2.5" spring leveling kit and 4.5" spring hanger is what you see above.
Old Jan 20, 2007 | 12:58 AM
Tenn01PSD350's Avatar
Tenn01PSD350
What is the legal issue in your state Kris?
Old Jan 20, 2007 | 05:53 AM
jetdoc's Avatar
jetdoc
I thought your truck was on the road? I know you can't pass inspection with any suspension mods and you need the stock tire size. If you need to "borrow" some parts to pass I can help you out.
