2002 E150 Transmission
Old 05-11-2016, 02:58 PM
occupa's Avatar
occupa
occupa is offline
Type U which I believe is 4R70W
145,000 mile
Rebuild a 110-115,000 or so. Fluid clear and full, no leaks
The problem is that when I shift from park to drive or from reverse to drive the forward gear is selected. I can feel it "catch" but not as strong as normal maybe could be described as soft
When accelerate I get a noticeable delay when going forward and then solid engagement.
Once that has passed the transmission operates normally; no delay from a stop and all up shifts and down shifts seem normal
Pretty repeatable. No check engine
What do you think? Thanks
Old 05-12-2016, 06:11 AM
JWA's Avatar
JWA
JWA is offline
Received 1,409 Likes on 1,111 Posts
When did this begin to show itself?
Mark Kovolsky will most likely appear so---he's kinda magical that way---but I'm wondering if the rebuilder didn't attend to or replace typical rebuild parts? If the fluid level is full and its the right type something inside the trans needs further attention.
Old 05-12-2016, 06:45 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,601 Likes on 1,074 Posts
I can't add much to that.
If you want to troubleshoot it, get a 0-350 PSI gauge with a 1/8" NPT thread. Insert it in the test port on the driver's side of the trans. Make sure you have a long enough hose that you can see what the pressure is doing when it's not acting right.
Old 05-12-2016, 09:28 AM
occupa's Avatar
occupa
occupa is offline
Just started in the last week
I will get a gauge and get back with you
Old 05-13-2016, 08:34 AM
occupa's Avatar
occupa
occupa is offline
Ordered a gauge and some fittings. They should arrive next week
As air will be trapped in the set up once connected, will I have "bleed" the air out to get a correct reading?
Let me know
Old 05-13-2016, 10:41 AM
Mark Kovalsky
No, you don't need to bleed air.
Old 05-23-2016, 09:39 PM
occupa's Avatar
occupa
occupa is offline
The gauge is 0- 300 PSI
Let me know what you think
The operation was fine until about the 4 minute mark on the video
I put it in reverse and then back to drive and it took about 30 seconds to get going
Old 05-24-2016, 06:38 AM
Mark Kovalsky
What do I think? I think I can't read the gauge. Nice drive around, but the scenery wasn't much. I heard what sounded like you moving the shift lever. If you could have said what gear you had it in this MIGHT have made some sense. All I got out of this is that you drove around.
Try this: Zoom in on the gauge so that we can see the numbers. Start with the trans in P. Move it to R, and say so. Move it to N and say so, repeating all the way to 1.
Go back to R. Hold the brake down with your left foot while pushing the go pedal to the floor. DO NOT HOLD IT ON THE FLOOR MORE THAN 5 SECONDS. Then put it in N and hold the engine speed at high idle for at least 30 seconds. This gets the hot fluid out of the torque converter.
Go back to D. Hold the brake down with your left foot while pushing the go pedal to the floor. DO NOT HOLD IT ON THE FLOOR MORE THAN 5 SECONDS. Then put it in N and hold the engine speed at high idle for at least 30 seconds. This gets the hot fluid out of the torque converter.
Go back to 2. Hold the brake down with your left foot while pushing the go pedal to the floor. DO NOT HOLD IT ON THE FLOOR MORE THAN 5 SECONDS. Then put it in N and hold the engine speed at high idle for at least 30 seconds. This gets the hot fluid out of the torque converter.
Go back to 1. Hold the brake down with your left foot while pushing the go pedal to the floor. DO NOT HOLD IT ON THE FLOOR MORE THAN 5 SECONDS. Then put it in N and hold the engine speed at high idle for at least 30 seconds. This gets the hot fluid out of the torque converter.
Old 05-24-2016, 03:56 PM
occupa's Avatar
occupa
occupa is offline
I will give if a go and let you know
Old 05-24-2016, 08:03 PM
occupa's Avatar
occupa
occupa is offline
Hopefully this is less scenic and more usefull
Old 05-24-2016, 09:47 PM
Mark Kovalsky
Your pressures are low. At idle it should be 50-75 PSI.
The reasons could be internal leakage, a bad electronic pressure control (EPC) solenoid, or a worn pump.
Old 05-25-2016, 01:50 PM
occupa's Avatar
occupa
occupa is offline
Mark
Thanks for the quick response
All pressures are low?
Or mainly the pressure at idle?
Is the pump a gear pump, positive displacement?
Changing the solenoid is in my skill set
What are my chances?
Old 05-25-2016, 02:07 PM
occupa's Avatar
occupa
occupa is offline
Mark
Old 05-25-2016, 08:25 PM
Mark Kovalsky
I could only tell at idle. Those were low. Mostly you didn't hold stall long enough to know what the pressures are. And I haven't found a 4R70W pressure schedule.
Yes.
Just barely above zero.
Old 05-26-2016, 05:53 AM
occupa's Avatar
occupa
occupa is offline
Mark;
Using that attached I think only my WOT stall on 2 is low and that could be from not holding it long enough as you mentioned.
I will try I again this weekend
Quick Reply: 2002 E150 Transmission
