Got a lil crankshaft end play here.
Old 05-11-2016, 09:16 AM
run6.0run's Avatar
run6.0run
run6.0run is offline
Look at this guys.
I'm gonna take another video today. It's actually going to not be as bad as I originally thought. The crank was trash,, but the block is good. UNBELIVABLE!!! Swap the crank and we are putting new rods in with a refresh. I mocked the replacement crank last night with new bearings and it has .005 end play. Crazy that the block survived!!! I thought it was going to be trash.
Old 05-11-2016, 01:09 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Does it wear one of the seals out faster on one side
Old 05-11-2016, 10:11 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
WOW
Old 05-11-2016, 10:24 PM
Jerky's_06 F350's Avatar
Jerky's_06 F350
Jerky's_06 F350 is offline
It was running, ran great, but it's clock was ticking.
That's amazing.
Old 05-12-2016, 02:03 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
That did not sound like bearing babbitt when you set it down. Was it
or something else? Also I am sure others want to see what the crank looked like.
Sean <BR>
6.0L Tech Folder
Old 05-12-2016, 09:34 AM
run6.0run's Avatar
run6.0run
I didn't get the follow up video yet. My spray cabinet pump motor went out. Maybe it's bad to say,, but I'm standing on the brakes of my shop!!! Lol. The motor n pump is an EXPENSIVE lil sucker. So I'm frantically shopping for either a pump,, or just replace the whole cabinet. It's a 3 week wait for the correct Gusher pump. Somebody's gotta have one,,, somewhere!!!
But that was the thrust bearing Sean. We honed it and it's off getting decked n cleaned now. It's getting a used crank,, and new rods. We are going to check the balance on it too. This build is going to be very nice,,, by nice,, I mean EXPENSIVE!!! Lol. Powermax, injectors, 05 hpop, 05 harnesses, our intake, ccv reroute, y pipe, I'm also making our own up pipes now too.
Old 05-12-2016, 10:28 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
3 weeks for the pump?? I was wondering how that turned out........
Old 05-12-2016, 01:54 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
For a pump have you asked these guys to look for you?
https://www.grainger.com
The other I can thinking of right off would be
McMaster-Carr
If the bearings on the pump are all that went have someone
stuff a new set in it and go. Had to repair a commercial line dishwasher
that chewed a bearing. We broke an elephant getting the bearing off.
The bearing house had a 50 Ton press we used to put it back on.
The other option is any good electric motor shop can rewind it if burnt.
But that can take time.
Sean <BR>
6.0L Tech Folder
Old 05-19-2016, 12:04 PM
run6.0run's Avatar
run6.0run
I finally shot a follow up vid.
Some might freak out about cutting his exhaust,,, oh well,,, I've spent countless hours trying to realign that crap. It's "stainless", but crappy stainless,, it's magnetic. We are going to use a band clamp on it initially,, then see how it welds later. Might get tigged.
usuallybowtie
06-04-2014 11:39 PM
rnelson664
10-15-2007 02:53 PM
freedump
11-03-2006 02:30 PM
flyhound
12-25-2004 05:17 PM
fordguy76
04-26-2004 09:42 PM
Quick Reply: Got a lil crankshaft end play here.
