EEC Chip for 94 F-250 w/ 460
Old 04-28-2016, 12:56 PM
sktobias's Avatar
sktobias
sktobias is offline
My 94 F-250 has stock 460 with K & N airfilter kit added. Stock exhaust system. Would like to know if there is an aftermarket EEC chip which would improve either performance or gas mileage. Both would be nice, but not sure if that is possible. Currently getting about 10 MPG. My main driving area is 5,500 - 8,000 feet above sea level, so an added factor. Do not want to spend $1,000's on an improvement. Thanks for your help, Stephen.
Old 04-28-2016, 01:01 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,173 Likes on 927 Posts
The only thing a chip is going to improve is the thinness of your wallet. You can do the same thing by advancing the base timing a few degrees.
That K&N is a known hot air intake, considered a step back and waste of money on this and many other Ford truck forums.
The factory exhaust, especially the torpedo converter, are known to hinder flow and performance.
Using the term 460 and better MPGs are mutually exclusive. It's not going to happen no matter what you do. Invest in a cheap beater for daily driving chores.
Old 04-28-2016, 01:02 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Nope. Best thing to do is just set your base timing to 12*BTDC and cut the air horns out of the intake.
Old 04-28-2016, 01:06 PM
Shadow944795's Avatar
Shadow944795
Shadow944795 is offline
Free up that exhaust system and hold it at WOT every chance you get. You will not get decent mileage out of a big block like that in a truck without either some serious areo work weight reduction to the max and driving like there is a egg under your foot. Chips are a huge waste of your money on these trucks.
Old 05-09-2016, 04:05 PM
IcutMetl's Avatar
IcutMetl
IcutMetl is offline
The only problem with gas mileage on a truck with a 460 is its owner's unrealistic expectations. It's never going to be good, and a lot of that probably begins with what you feel "good" is. The only thing a magic chip will do is lighten your wallet as someone has already mentioned. Spend money and make it flow better or spend money on fuel, those are our two best options.
Pfricks
Computer Chips & Tuners
06-12-2018 10:21 AM
egress
21
02-06-2011 08:30 PM
Tyson82
08-15-2006 10:04 AM
mountaincat68
05-17-2005 06:47 PM
MW95F250
02-05-2003 09:50 PM
Quick Reply: EEC Chip for 94 F-250 w/ 460
