1993 rear end
Gearing depends on what you are looking for and what engine you have (maybe transmission too, but that won't have as much impact).
If you have a 302 I'd agree with conanski. My '71 Bronco (302, 5 spd OD manual trans, 33" tires, 4.10 gears) is fine for almost everything. It could pull 3.55 gears empty, and might be a little better on the highway like that. But when towing my boat (~7000 lbs total weight, Bronco and boat) it's a dog. 4.10s are a good compromise, 4.56 would be better if I did much towing / hauling.
If you have a 351 personally I'd go with 3.55 gears. I had that in my '95 F-150 (351W, E4OD, 33" tires, 3.55 gears). It was just what I wanted empty. And several times I carried my camper and towed a Jeep (10,000 ~ 11,000 bs total truck and load), including one trip through the Colorado Rockies. It slowed down up the steep long hills, but I still thought it was fine. And it had no trouble pulling OD at 70 mph on flat land even with that load. If you only hauled loads like that 4.10 gears might be better even with a 351, but I really liked the 3.55s I had.
I don't have any experience with the 300. People say spinning it faster just uses more fuel without really giving more power, so I'd be tempted to go with 3.55 gears there as well. But that's just a semi-informed guess.
I'm about to swap in 4.10s with 31s. That gear:tire ratio is about what every truck that was sold "for towing" in the 80s and 90s came stock with. I'd personally much rather be speed limited by deep gears and high RPMs than not have deep enough gears.
I wouldn't tow anything more than a jet-ski with an E4OD in OD. It's just making a lot of heat and being hard on the transmission (particularly the torque converter clutch) for no good reason.
Everyone who knows anything about E4ODs (including Mark Kovalski, former Ford auto trans engineer who's on here a lot) agrees that towing with the E4OD in OD is fine, it was designed for it. And an auto trans generates very little heat when the torque converter clutch is locked. Now if the trans keeps needing to downshift and can't keep the clutch locked, then yes, you should take it out of OD. But as long as it can easily pull OD there's no reason not to
That's true, but few stock trucks will be holding OD with the torque converter locked while towing any sort of a load (larger than a jet ski) and stock gears, you'll just be lugging it down to ~1k and then downshifting at every little hill. Maybe it would work better across a really flat part of Kansas or something but nowhere else.
....If you have a 351 personally I'd go with 3.55 gears. I had that in my '95 F-150 (351W, E4OD, 33" tires, 3.55 gears). It was just what I wanted empty. And several times I carried my camper and towed a Jeep (10,000 ~ 11,000 bs total truck and load), including one trip through the Colorado Rockies. It slowed down up the steep long hills, but I still thought it was fine. And it had no trouble pulling OD at 70 mph on flat land even with that load. If you only hauled loads like that 4.10 gears might be better even with a 351, but I really liked the 3.55s I had....
Which is why I said...
I guess I didn't say it explicitly, but I think it's pretty clear that I didn't pull the Colorado Rockies in overdrive. But that's what 3rd gear is for (and sometimes 2nd). But from Minnesota I could keep it in OD for almost all of the drive through southern MN, through Iowa, across Nebraska and even across all of eastern Colorado. Turns out a lot of the country is a lot like Kansas.
We're thinking pretty close to the same. But for instance driving across South Dakota there are MILES of flat followed by a short hill and then more flat. The 3.55 gears let me pull OD across the flats and then every so often I'd have to take it out of OD for half a minute. Using OD like that is well worth it for me. But if you'd prefer to leave it in 3rd, that's OK too.
And a little off topic, but that truck did something that made driving like that easier. I was using the speed control and as it went up hills it would slow down, but it wouldn't downshift. So when I noticed the speed drop off I'd kick the speed control off and kick it out of OD until I topped the hill and got back up to speed. By contrast my current truck (460 and 4.10 gears) will downshift and snap everyone's necks as it maintains whatever speed I set. So I end up not using the speed control with my current truck unless it's empty. I actually found the 351/3.55 gears MUCH better for the hauling I do than my 460/4.10 setup.
