E250 vs e350
E250 vs e350
Hello, I have a 1991 e 350 ecoonline, the rear end is shot, can I used e250 rear end with the same springs, or must it be a 350 rear end. Also what about a e 150. As I look, what years should I search for, 1985-1991, or will othe years work. This is a bucket truck that I use on my own property, I would like the option of taking it on the road, but no a necessity. Can I cut the u bolts and leave the springs attached, or should I take out everything. Thanks, located in Wisconsin.
The 97+ 250 uses a semi-floating rear axle, I believe the earlier ones were both full-floating, might possibly be the same, but I'm not certain. I have replaced several rear ends, always cut the U-bolts and left the springs in, I would never put a 1/2 ton axle in place of a 3/4 or higher.
52' fordnut
09-24-2012 05:45 AM
imlowr2
05-02-2005 06:50 PM
don_79f250
06-04-2004 10:01 AM
