Sponsored by: Kumho
Rear axle question
Old Jan 27, 2000 | 10:37 AM
deleontow's Avatar
deleontow
Rear axle question
Old Jul 13, 2001 | 05:06 PM
1ole4d's Avatar
1ole4d
Rear axle question
What would cause your rear end to be off set? The rear end on my rig sits an inch or two to the right (passenger side). My truck has a puppy walk and I need to know how to fix this. Any ideas?
Old Jul 14, 2001 | 07:40 AM
Nathan's Avatar
Nathan
Rear axle question
I would look for bent or damaged leaf springs and mounting points (shackles).
Nathan
Old Jul 14, 2001 | 11:01 PM
1ole4d's Avatar
1ole4d
Rear axle question
Well...I did find that the front driver's side shackle bount is loose. The bottom rivits are coming out plus the u-bolts are bent on both sides. i'm replacing the u-bols monday but I'm not sure how to fix the rivits. ???
Old Jul 15, 2001 | 07:00 AM
Nathan's Avatar
Nathan
Rear axle question
Remove the rivets and replace with Grade 8 bolts.
Nathan
