E250 vs e350
Old Apr 18, 2016 | 10:25 AM
Buickman85's Avatar
Buickman85
E250 vs e350
Hello, I have a 1991 e 350 ecoonline, the rear end is shot, can I used e250 rear end with the same springs, or must it be a 350 rear end. Also what about a e 150. As I look, what years should I search for, 1985-1991, or will othe years work. This is a bucket truck that I use on my own property, I would like the option of taking it on the road, but no a necessity. Can I cut the u bolts and leave the springs attached, or should I take out everything. Thanks, located in Wisconsin.
Old Apr 18, 2016 | 11:04 AM
maples01's Avatar
maples01
The 97+ 250 uses a semi-floating rear axle, I believe the earlier ones were both full-floating, might possibly be the same, but I'm not certain. I have replaced several rear ends, always cut the U-bolts and left the springs in, I would never put a 1/2 ton axle in place of a 3/4 or higher.
Old Apr 18, 2016 | 03:56 PM
vettex2's Avatar
vettex2
I think he wants to use a 3/4 ton rear end in a 1 ton chassis.
Old Apr 18, 2016 | 09:48 PM
Conanski's Avatar
Conanski
E250 uses a D60 semi floating axle while an E350 will have a D70 full floating axle. The D60 will bolt right in and work just fine but it doesn't have the same weight rating.
Old Apr 18, 2016 | 10:51 PM
Buickman85's Avatar
Buickman85
Thanks for the info, I wanted to know if I could use a 250 if I came across one,I currently do not own one. What about out of a truck?
Old Apr 19, 2016 | 02:11 AM
maples01's Avatar
maples01
Van is wider and the spring perches would be off, along with shock mounts.
52' fordnut
Sep 24, 2012 05:45 AM
justshootme84
Offroad & 4x4
Nov 24, 2006 03:28 PM
imlowr2
May 2, 2005 06:50 PM
don_79f250
Jun 4, 2004 10:01 AM
deleontow
Jul 15, 2001 07:00 AM
