Turbo
There are rebuild kits available from several places; good idea to clean the vanes while in there.
As for interchangeability, I can't say for sure.
I know at XDP they sell stock Garretts for 2003, 2004-2005, and 2005.5-2007.
All I've ever heard is that the 03-04 units whistled louder.
OK thanks a buddy asked to use my stock turbo and was not sure it would work for him.
Is he going to use a bearing out of your's to fix his?
difference between 03/04 and the 05/07 is the pedestal mount. The early turbo's have a slightly bigger discharge volume and they have fewer turbo fins, why they whistle more than a late turbo. As long as the pedestal is the same, it will work.
get the bearing kit, think they call it a 360* bearing.
Thanks for the info. He is gonna drop mine in to see if it will work for now till he can get the bucks for a new one. He just did headgaskets and BP diesel remote oil cooler and after just a couple hundred miles his turbo took a dump. Mine has a little play in it but worked when I took it off. Thanks again.
