6.0 engine idle rpm
6.0 engine idle rpm
Just changed the oil in my 6.0 and I'm sitting here looking at my tuner and is telling me my idle rpms are about 770.
Before I changed my oil it idled around 750.
It's running fine, I was just wondering why it changed? More pressure to the injectors with the newer oil?
Neither is the correct idle spec for a 6.0, so if it's cold it's likely running fast because of that. You need to be up to operating temps of at least 190*f ECT/190*f EOT to get an accurate HPO reading.
You can't look at ICP alone, you have to compare to IPR%. You should be at either 580/22% or 620/22% hot idle.
