Sponsored by: Real Truck
Front Hub Locks
Old Apr 3, 2016 | 11:37 AM
catalinaflyer's Avatar
catalinaflyer
Front Hub Locks
So I noticed the past few days my 09 F250 was clunking in the front end when turning hard even with the hubs in auto so I knew there was an issue in there somewhere.
This morning I took the jack and found the passenger side would not release no matter which way the lock was turned. Pulled the locking assembly out and found a couple of the pieces of plastic cage broken (truck has 250k miles) which is to be expected I guess but the locking ring that holds the inner piece that slides over the axle stub was off and hanging next to the c-clip on the axle.
So with the plastic of the cage already being broke and the mileage on the truck it's clear I need a new lock for that side.
Here's my dilemma, I have to deliver a conference room table 200 miles away tomorrow morning that they need for meeting tomorrow afternoon at 3:00pm. I cut the rest of the plastic pieces and took the gears out leaving just the cover with the diaphragm and put it back on the hub. I can't come up with any logical reason why I can't drive the truck this way but just want to bounce it off the experts here before I take off on a 400 mile trip in the morning. The only thing I can come up with is if I were to engage the 4wd the vacuum might suck the auto-lock diaphragm in and pop it but otherwise I can't find any reason to not run it this way, the hub is still sealed up and free-wheeling just like if it were in 2wd anyway.
Old Apr 3, 2016 | 12:14 PM
Rongold's Avatar
Rongold
BROKEN HUB
You're correct. Just reinstall the hub and go on your way.
Old Apr 3, 2016 | 12:36 PM
catalinaflyer
Thank you sir.
I just picked this truck up last summer with 250k miles on it (for next to nothing) and I'm sure there's some serious maintenance needing done on the front end as I see seal dust covers riding on the axles etc. but don't have the time at the moment or the heat hooked up in my new shop.
adjc
Oct 27, 2018 07:49 AM
cabloom300
Dec 17, 2014 12:33 PM
magnumak1
May 9, 2012 10:01 PM
camsamjam
Mar 21, 2006 04:51 PM
bent1955
Offroad & 4x4
13
Feb 27, 2003 08:13 PM
