82 F150 cancel cam fixed but still no turn or brake lights
My cancel cam broke last year so I took it out and didn't have time to put the new one in. While out I had no taillights/brake lights. I put the new camback in last weekend and now I have taillights but still no brake lights or turn signals.
I checked the fuses and one was burnt so I replaced it and I have tried a new flasher but still no go. Hazards work but only to the front not the back. I wasn't using my multimeter correctly so I am not sure about power through the turn signal flasher.
Everything I have read says turn signal switch but that is only available through LMC and if I can fix it without going that way of course I would prefer it.
Any ideas would be great.
Thanks,
Shawn.
Thanks,
Shawn.
RockAuto has the switch, albeit a little spendy. Tilt or no-tilt?
Y'know, I have a switch at home somewhere (oh snap, where is it?). Didn't fit my '85 because of the angle in which the signal lever arm screws in, doesn't match the column. I think I was just sloppy about what part I ordered. I wonder if this one would fit yours. I'll let you know if I find it.
lcguy1
09-02-2012 11:11 PM
Kentwa
16
04-03-2012 05:07 PM
feeniks4.9
02-12-2008 11:01 PM
