Advice needed for an oil change on a 1950 F1 226 6 Cycle
#32
My guess is that they are much closer to the block, and out of the direct path of the fan. Also, they are much farther away from the carb in case there were vapor lock issues, but they had those anyway as I recall. Used to put wooden clothespins on the fuel line to fix that.
#33
#34
So digging through the parts where i recall the linkage to be hiding and I guess this is all I have, thought i had more parts than this?
Looks like ive got the longer throttle shaft #9747.
Linkage. #9724
Spring # 9624
And the throttle or ?? # 9805
And the heat shield. All will fit in large usps box.
#35
Posted more pics of my engine, carb, etc
I took some more pictures of my carb and engine since people said they needed a few more complete pictures.
Any thoughts on these? Any concerns? Also, if you look at the engine block there is a bolt missing from the block closest to the cab. What should be there?
And if I could find a heat shield, would I have to drill holes into the engine block to attach it?
Brian
Brian
#36
#37
It looks like you have the throttle brackets or at least parts of it?
The missing bolt on the rear corner of head might be for a ground strap??
Did you get my last message? You can have the heat shield for the cost of shipping. Send me your info agian via another pm or at my email. Jf madsen at yahoo.com
#38
#39
#40
something I noticed and it's the same on my 226 H is that the intake carburetor mount is tilted towards the float bowl. I've been rebuilding mine and it definitely has a lean and it's cast that way. Just wondered why and if that was the same for all of them? Makes the carb look tilted even though it's installed correctly
#41
#42
Bubba Jones
02-19-2017 07:00 AM
Turbo Dog
2009 - 2014 F150
12-12-2016 10:45 AM
