Advice needed for an oil change on a 1950 F1 226 6 Cycle
  #31
Old 04-01-2016, 10:11 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Well there you go, trying to ask intelligent questions!
I dunno. Maybe the beancounters started to prevail. I got nothin'.
  #32
Old 04-02-2016, 01:11 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Originally Posted by Jolly Roger Joe
So, not trying to start an argument here, but why doesn't the V8 need a heat shield? Don't the exhaust manifolds get hot on them?
My guess is that they are much closer to the block, and out of the direct path of the fan. Also, they are much farther away from the carb in case there were vapor lock issues, but they had those anyway as I recall. Used to put wooden clothespins on the fuel line to fix that.
  #33
Old 04-02-2016, 01:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
I always assumed the heat shield was to keep the intake warm. 6's need all the help they can get in winter with their long manifolds. Even in summer the end cylinders run leaner.
  #34
Old 04-03-2016, 03:50 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
Makes ya wonder why so many of them are missing nowadays.
So digging through the parts where i recall the linkage to be hiding and I guess this is all I have, thought i had more parts than this?
Looks like ive got the longer throttle shaft #9747.
Linkage. #9724
Spring # 9624
And the throttle or ?? # 9805
And the heat shield. All will fit in large usps box.
  #35
Old 04-03-2016, 04:43 PM
Thbifeb's Avatar
Thbifeb
Thbifeb is offline
Posted more pics of my engine, carb, etc
I took some more pictures of my carb and engine since people said they needed a few more complete pictures.
Any thoughts on these? Any concerns? Also, if you look at the engine block there is a bolt missing from the block closest to the cab. What should be there?
And if I could find a heat shield, would I have to drill holes into the engine block to attach it?
Brian
  #36
Old 04-03-2016, 05:18 PM
3twinridges's Avatar
3twinridges
3twinridges is offline
Whatever you do don't drill holes in the block. Lower eye on shield goes on top motor mount stud and upper bracket attaches to the corner of the head with a threaded hole already.
  #37
Old 04-04-2016, 09:31 AM
jmadsen's Avatar
jmadsen
jmadsen is offline
It looks like you have the throttle brackets or at least parts of it?
The missing bolt on the rear corner of head might be for a ground strap??
Did you get my last message? You can have the heat shield for the cost of shipping. Send me your info agian via another pm or at my email. Jf madsen at yahoo.com
  #38
Old 04-04-2016, 09:51 AM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,481 Likes on 1,417 Posts
What I see he needs most for throttle linkage is the correct bellcrank on the firewall so it pulls correctly.
The heat shield will attach with existing bolts/studs. When you see it, it will become apparent.
  #39
Old 04-04-2016, 05:47 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
The missing bolt on the head is where the battery positive cable attaches for ground on a stock 6 volt positive ground system. Or, if you've converted to 12 volts, that's where the negative battery cable would attach.
  #40
Old 04-05-2016, 10:59 AM
bhalemail's Avatar
bhalemail
bhalemail is offline
something I noticed and it's the same on my 226 H is that the intake carburetor mount is tilted towards the float bowl. I've been rebuilding mine and it definitely has a lean and it's cast that way. Just wondered why and if that was the same for all of them? Makes the carb look tilted even though it's installed correctly
  #41
Old 04-05-2016, 11:11 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The entire engine/trans is tilted 3 - 4 degrees to the rear. The angle on the carb should make it level at the float bowl.
  #42
Old 04-05-2016, 03:43 PM
bhalemail's Avatar
bhalemail
Thanks for that bit of info. I guess I'm not used to seeing them on an engine stand but that sure does make sense.
LeeG
1997-2006 Expedition & Navigator
06-06-2017 09:24 PM
Bubba Jones
02-19-2017 07:00 AM
Turbo Dog
2009 - 2014 F150
12-12-2016 10:45 AM
RobertJohn
11-20-2014 01:09 PM
JetFuelBurner
01-09-2013 05:58 PM
Quick Reply: Advice needed for an oil change on a 1950 F1 226 6 Cycle
