I just bought a no rust 94 f250 4x4 7.5,very clean but I am changing all the fluids for well being.but when I pulled the rear cover off the clutch paks on the end of shaft doesn't look like anything I ever seen.not your normal center section,cannt find anything on net. code is s132G topnumbers then 4L10 10 2 3L02.thanks for any and all help
this has a 460 and a e4od with a banks tranny computer,on take of I am getting a shudder from the rear until about 5 mph.any thoughts,I thught it might be the rear.
It's not the limited slip......the yoke that slides into the driveshaft has been known to go "dry" and cause this issue. Pull it apart and regrease it.
