Slight miss/hesitaion at idle
Hi. I've got a 2000 Excursion with 36,000 miles on it. It has a slight but noticeable miss at idle. No codes or stored misfire data in the computer. According to the very detailed service history from the original owner, it's never had the plugs replaced. It's not been 100,000 miles, but they are 16 years old. Could this be causing my miss? How about the coils/boots?
Thanks
Thanks
Really, 36000 miles?
Both my excursions had miss issues due to water coming in from center joint of cowl (the plastic piece between windshield and hood).
I siliconed the leak and miss went away after water dried up.
I wouldn't think coils would be bad, but I would put new plugs in, if nothing else just so you can see if any water or rust is in the spark plug holes.
I've used "Standard" brand boots with great success. They were every so slightly different than the stock ones. I could tell the mold wasn't the same.
But, they've held up well, they've been in my truck for the past 10+ years, and never an issue.
Get some dialectric grease. Put a small amount at the top of the boot where it seals to the COP, and then a small amount around the inside of the tip where it'll seal against the plug.
Doesn't sound like you have a bad coil, especially if you don't notice a miss when it's under load.
Clean the MAF too...
pjw73nh
09-08-2011 09:45 AM
