Fuse Amperage Ratings
I'm installing a fuse panel as part of my 12 volt upgrade on my '52. I know the original circuit breakers were only 30A and 15A, but what amperage should my new circuits be? I'm installing a 12 slot panel and am planning on running everything through that. I also have installed a LMC HD headlight harness, so I've moved the power out of the light switch to the battery.
Every electrical component has a maximum amperage that needs to be protected by a fuse rated for a lower amperage and a wire size sufficient to carry that amperage. If there is a problem with the circuit you want the fuse to
go before the component is destroyed or the wire burns. There are lots of automotive publications that give amperage and wire size for automotive electrical components.
In my last reply I need to correct the statement about Amperage.
If the devise uses up to say 12 amps the fuse would need to be 15 amps to assure enough power to run the devise before the fuse goes. Even if it uses 10 amps you'd still want to use a 15 amp fuse. In either case the wire would need to be able to handle more than 15 amps.
It really depends on the watts the devices attached to the circuit require. Volts x amps = watts. A 20 watt device at 6 volts would require 3.3 amps. The same 20 watt device at 12 volts requires 1.7 amps. Conversely, a 20 amp, 12v cigar lighter uses 240 watts or 40 amps at 6 volts.
So, choose the devices you want to place on a circuit, add up their watts or amps and do a little quick math. Don't know their requirements? Normally not difficult to find spec sheets online or look in the owner's manual of most cars to get an idea of the power required.
To learn about automotive electrics go to Autoshop101.com, click 'Online Instruction' on the left margin and begin with 'Electric Fundamentals'. It cracks me up how much time guys will spend on researching how to smear some bondo and sand it back off yet avoid learning about automotive electrics. If you use the site I mentioned you'll probably have fun and kick some electron butt when you're done. Shoot, you might even begin to finally understand The Big Bang Theory. LOL
sere0501
48
01-04-2015 12:39 PM
90pioneer
04-25-2013 05:54 AM
pjhjah
10-27-2009 01:31 AM
Kasilof Ron
09-10-2004 10:01 AM
