I'm buying a 96 F250 with the 460 and I was just wondering which type of gas I need to put in it, whether 87 grade is sufficient or I need to put a higher grade in it, thanks guys!
My 1989 model likes at least 89 octane. It has good flowing exhaust and the air intake system has been opened up as well as a slight timing bump. All stock will probably be fine on 87
95 250 with 460 I have run em all grades it actually seemed to run better on 87.
No change overall except cheaper gas bill!!
That's because it DOES run better on 87. If you run higher octane fuel in an engine whose compression ratio is not high enough to require it's use, you will lose low - mid range hp.
Put 93 in your low compression engine and you're wasting your money.
I have to run 89 minimum in mine. Otherwise it'll ping like a **** in the mountains. Have to run stock 10 degrees also, it just isn't happy with any more.
