Help with door latch
Old 02-15-2016, 04:55 PM
dobenator's Avatar
dobenator
dobenator is offline
Can some one( I know you can cause I've seen how this place works) give me direction or advice on how to adjust the driver side door on my 53 f-100? It closes and latches but it is not right.
Old 02-15-2016, 05:14 PM
chad77's Avatar
chad77
chad77 is offline
The guide stub looks low? Is it the door sagging down? If that's fine, just adjust the striker plate down.
Old 02-16-2016, 10:23 AM
dobenator's Avatar
dobenator
I dont feel any play when lifting the door but it closes much easier. and when its closed it looks like it supposed to.( it fits the hole nicely)
Old 02-16-2016, 11:25 AM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
I do believe I would put a bit of lubrication on the hinges, the rotary latch and the striker.
Old 02-17-2016, 02:26 AM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
Like Ray said it needs lube but based on what I see I would pull that nasty thing out of the door, clean real good, lubricate, and re-install . Then let us know how it works, a little more description than "it ain't right". Does it feel loose, back and forth play, up and down play, comes un-latched, etc...you get my drift.
Good luck
Old 02-18-2016, 10:40 AM
dobenator's Avatar
dobenator
Good luck
I dont feel any play in the door at all but if I lift it up it closes correctly. When shutting the door normally it sounds like it is hitting something solid, thus the picture of the door latch hitting too low on the striker. I will definately lube both doors but thats not going to stop the uneveness of the door. Is there some adjustment on the hinges? I dont see any on the latch of the door or the frame. It will latch when closing but not all the way, you got to slam it pretty hard and it stays shut.
Thanks for all your help.
Old 02-19-2016, 01:05 PM
truckeemtnfords
There is adjustment both at the hinges and and the cab side of the the latch. If you can lift the door and all is well it sounds like you have some slop in your hinges. You can try to adjust it out or you may need to rebuild the door hinges with new pins.
ericthor
22
10-13-2016 04:54 PM
Sparky83
1999 to 2016 Super Duty
10-11-2012 10:34 PM
michaelmilburn
04-13-2012 01:22 PM
berry1234
15
08-18-2010 11:39 AM
shooer
04-10-2008 06:17 PM
Quick Reply: Help with door latch
