1994 f150 climate control lights
Hi everyone my 94 F150's climate control selector **** (Vent, Floor, A/C, etc) is no longer illuminating and I want to replace the bulb. I've been searching for a guide on how to get to these bulbs but I can't find one and I would like to avoid damaging any part of the dash and console. Can anyone give me some quick info on how to properly access these bulbs? Thanks!
VERY CAREFULLY pry off the trim strip that goes across the dash under the pad. That will expose two screws (that screw into the brass colored squares) that you remove and then the bottom of the trim panel also just pulls off. then you'll see the two screws on each side if the HVAC controls.
grip1968
1997-2006 Expedition & Navigator
12-04-2013 09:46 AM
