1999 F350 Rear Brake Sticks
Got a tough one I can't figure out on my 1999 F350 with the 7.3L and a manual transmission... I'm very mechinically included and cannot figure out why my left rear rotor is always hot recently. The rotor and pads are about 6 months old and still in great shape.
A few weeks ago, I noticed the slight smell of burning brakes. Checking all four rotors, I noticed the left rear was hot. So I proceeded to replace the caliper and bracket/slide pins. I then bled the brakes and tried it out. It still got hot.
Next I replaced the rubber hose to the caliper (I didn't have high hopes this would fix it, because it bled well and seemed to have good flow.) I also disconnected the brake lines and blew them out with air, re-bleeding the system. This did not help either.
Next, I focused on the parking brakes. These were trashed. I spent a good amount of time replacing all the parts... Including new pads, hardware and cables. I adjusted them to the point that they worked well, but I was sure niether side was dragging at all.
After all this, the left rear rotor still gets hot. I put the rear axle up on jacks and ran the truck in gear to spin the rear tires. Feeling the rotor, it is the disc part that gets hot, not the drum for the parking brake. It is still drivable, but I don't like driving it like this. It never gets so hot that it smokes, just too hot to touch or it will burn your hand. The passenger side never gets hot like this.
Am I missing something? Should I try the rubber hose that goes from the frame to the axle next? Again, I don't have high hopes for this because the caliper always bleeds easily through this hose and the passenger side doesn't get hot. Could this be ABS related?
Any help is appreciated.
Thanks,
Spenser
Thanks,
Spenser
could it be where the ends of the brake pads ride being rusty, so they can't easily slide away from the rotor?
maybe try installing the caliper without brake pads and seeing how it moves sideways on the caliper pins
seems to always be that same caliper on all the fords. i wonder what it is. .i fixed mine by putting powerstop calipers and rotors on with the mounts and everything.
Thanks for the help,
Spenser
Not knowing what else to try, I went back to autozone and got a 2nd caliper to change out. It's been two days and it seems to have fixed it! No more hot rotor, and the truck rolls like it should on slight inclines.
So it seems a cheap $50 autozone remanned caliper was to blame.
Thanks for the help!
Spenser
Spenser
