2wd vs 4wd rear end.
I'm guessing the center pin would be the same location no matter, worse case is you would have 1/4 of spring hanging over your perch/pad on each side. Could just weld a little metal to it so it fits snug between the ubolts if they are different. Just bought a 4x4 transmission and I had him throw in the leaf springs and a few other things as part of the deal.
on
I assume the gearing of the donor is different than your truck? Otherwise why would you swap the rear end?
AFAIK the spring perches are the same. I swapped a Bronco rear-end into my F150 (to change the gearing) and it worked fine. My F150 was also converted from 2wd and so has the 2.5" springs in the rear.
59flatbedford
08-11-2006 06:30 PM
