4 inch lift question
hey guys I'm looking into saving up for a lift kit. Nothing crazy prob a rough country 4 inch lift. my question is what do you need as far as extensions. like with 4 inches will I need to extend the brake lines, drive shafts, and such? or is that not high enough to where it won't put stress on it.
thanks yall
2001 f250 7.3
thanks yall
2001 f250 7.3
Some of it will depend on the kit you get, but generally brake lines and such will be fine. Just be sure to get a drop pitman arm, maybe shim the carrier bearing, and if you're going with bigger tires, add a good steering stabilizer and change out the high pressure line on the steering gear box (a new stock version will work)
1loud89
12-03-2011 12:34 AM
randyb1984
07-07-2009 03:53 PM
SuperDutyF250
04-24-2009 12:48 PM
96-5spd302
10-02-2003 02:56 PM
