2000 F-150 Base 4.6L 2 door long bed
Old 02-06-2016, 11:37 PM
josevidal1970's Avatar
josevidal1970
josevidal1970 is offline
Good evening,
I really like this site. What I did not find or may have overlooked was info on tail light troubleshooting.....
I just had my truck's tail lights fixed.
Now, I know I need rear brake shoe replacements a.s.a.p.,
my question is, will the tail lights stay on after I shut my truck off and close its door because it needs brakes, or can a blown fuse cause the brake lights to stay on?
Thanks!
Old 02-07-2016, 07:39 AM
Grizzly4x4's Avatar
Grizzly4x4
Grizzly4x4 is offline
I wouldn't think either of those could cause the lights to stay on.
Old 02-07-2016, 09:13 AM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
the head lights are staying on when you get out ?...are you saying the tail lights do this at the same time.? and go off when the head lights go off ?
Old 02-09-2016, 12:58 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Originally Posted by josevidal1970
Good evening,
Thanks!
The tail lights light one element and the brake lights light the other element in the rear bulbs.
You do not really make it clear what is the problem you are having. My best guess is that the brake lights at the rear are staying on when there is no one in the truck pressing the pedal. The first thing I would check in that case is the adjustment of the brake light switch at the brake pedal.
If the tail light or running light is staying on, turn off the headlight switch. Or if it has automatic headlights either turn that feature off or adjust it so the lights go off quickly enough to suit you.
If the problem is the brake idiot light on the dash stays lit or is coming on then going back off, I would check the brake fluid to be sure that it isn't low.
Old 02-09-2016, 09:31 PM
Todd Rasmussen's Avatar
Todd Rasmussen
Todd Rasmussen is offline
x2, check brake pedal return, and switch behind brake pedal if it is the brake light's staying on,, and what he said
Redstroker73
01-23-2017 08:51 AM
Dodge-My-Cummins
1999 to 2016 Super Duty
12-22-2016 08:50 AM
bbender85
02-04-2009 01:10 PM
alliswc
1997 - 2003 F150
03-07-2008 02:01 PM
48fordf3
04-15-2006 07:53 AM
Quick Reply: 2000 F-150 Base 4.6L 2 door long bed
