head lights work, brake light doesn't
Old Apr 11, 2006 | 07:49 PM
48fordf3's Avatar
48fordf3
Getting the truck ready. Replaced the light switch on my 48 ford. Headlights and parking lights work, brake light doesn't. Going to get a new stop light switch but I wonder what wiring screw up I may have done.
Anyone have this problem before?
Old Apr 11, 2006 | 07:58 PM
Randy Jack's Avatar
Randy Jack
Do your rear tail lights come on with the headlights, or are they out too? If they are out also, check your grounds. If it is only brake lights that don't come on, it will probably be the brake light switch. Tail and brake lights both ground through the bed to the frame.
Old Apr 12, 2006 | 04:29 AM
48fordf3's Avatar
48fordf3
Only brake lights don't come one
Only brake lights, I'll swap out the switch and see what happens. Thanks for the reply.
Old Apr 15, 2006 | 06:23 AM
48fordf3's Avatar
48fordf3
That did the trick...
That worked although I still think I miswired somewhere. But if it ain't broke...
Old Apr 15, 2006 | 07:53 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
For future reference take the two wires off the switch put a peice of wire between the two and see if the lights work. If they work the switch is bad if they don't work keep looking.
