Rear brake grabbing ?
Gathering theories here. Preliminary info: 1994 F150 4x4. Truck sat for a WHILE prior to my saving it from the crusher. I've had the drums off and there's no fluid leakage, dry as a bone. Shoes are 2/3 worn and everything looks as it would after sitting.
Trucks sits for a week and then the first time I apply the brakes, like at the end of the driveway, the right rear grabs and slides. Once on the road if I ride the brakes for a couple seconds then there's no more issue until it sits again. It's worse in rainy weather.
Will old organic linings absorb enough moisture to cause the grab? Never had one do this unless leaking fluid. Only other explanation I could see is the cylinder sticking slightly. What do you guys think??
I just replaced both e-brake cables before going for a safety inspection. That also allowed my my checking things out that might cause the dragging brake.
I have several little projects to undertake once it warms up a bit.
dylancroghan
10-26-2014 10:46 AM
DW2455
09-18-2004 02:09 AM
