One brake locking up.
Old Oct 23, 2014 | 09:57 AM
dylancroghan's Avatar
dylancroghan
Bled the brakes yesterday on my 84 cause the pedal was getting way to low. At first I thought everything went well because the pedal was back up to normal. When I took it out for a test run I found that the right rear brake was locking up way to early. Before when the pedal was low all the brakes seemed even. What happened!?
Old Oct 23, 2014 | 10:04 AM
85e150's Avatar
85e150
Did you spill brake fluid into that brake? That will cause a lockup.
Basic brake adjustment? If one brake is tightly adjusted and the other isn't, again, one will lock up long before the other.
If one side has a problem of one kind or another, and simply isn't working, the other--working properly--will lock up without the other.
Go with the simple first, that might could be it.
Old Oct 23, 2014 | 12:45 PM
Franklin2's Avatar
Franklin2
Pull the right rear. The cylinder is probably leaking, or is rusted and sticking. If you do not find any of that, then the parking brake cable may be sticking on that side.
Old Oct 26, 2014 | 10:46 AM
kevin206's Avatar
kevin206
Any time I've had this happen I have found one of two things...
1) a completely stuck/frozen wheel cylinder on the side that is NOT locking up...not applying.
2) a sticking cylinder on the side that IS locking up...not releasing.
I've popped a few cylinders over the years, but I can't really recall a "locking up" issue. But then again, the loss of brake power and fluid running down the inside of my tire makes for easy trouble shooting!
Oh, and this appearing after the bleed procedure could simply be that you NOW have fluid back there to operate the brakes. i just ran into this on my dads truck. For a few years he has been wearing out front pads, but the rear shoes were showing no sign of wear. It turned out that the rear brakes had NOT been applying for all of this time. The bleed exposed rusted rear cylinders. After new cylinders the truck will throw you forward when hitting the brakes! It had gone unnoticed because the front brakes were doing the job just fine...at the expense of accelerated wear.
Code3cody
Large Truck
Apr 17, 2017 09:45 PM
hurst1979olds
29
Aug 30, 2016 10:01 PM
66-Ol'Henry
Jun 7, 2015 03:28 PM
jmgrif
Aug 7, 2012 07:21 AM
6686L
Sep 14, 2011 08:29 AM
