After everything is warmed up and it had that shudder does it sound any different at idle like maybe a little rougher idle or different knock sound or is it just the same as when you first fire it up
It starts quickly, idles perfectly after first starting and after it's hot. No noise changes in idle. Same as when it's cold.
FINALLY!!! The skipping under power with a load turned out to be the ICP sensor. The truck pulls nice and smooth now! Jarrett, your the man! Thank you for your time and effort. I hope we get the chance to spend more time at the brewery sometime soon.
