Speaker locations...
Hey Guys,
Going to get around to putting a small stereo into the old girl. I have a modern headunit to use, and just need a couple speakers.
I do not have a stock radio at all, just the blockoff plate, and speaker grille, with no hole cut into the dash over the years
I am thinking about a few options:
- Behind the seat
- Under the seat
- Stock Dash location
Kick Panels are out of the question as thats where my fuse block and EFI computer reside.
Do I need an adapter to use a speaker in the dash?
Anyone try both behind seat and under seat (if so what sounded better)?
Thanks!
John
- Behind the seat
- Under the seat
Thanks!
John
You should be able to get any number of modern speakers into the original location. Were it me, I would consider a bass unit in the dash and a small mid-range on either end of the dash, hidden up near the floor boards. Something like that should give you a good stereo sound and be well hidden.
This may be a little over the top but when placing speakers it's good to know that the low frequencies are omni-directional and the high frequencies are directional. In other words, the bass speakers can be placed almost anywhere but the mids-tweeters work best at somewhere around eye level and pointed at the listener. It might sound like a bit too much work for our trucks but high frequency drivers are easily installed in A-pillars or dashes and bass drivers can be hidden under/behind seats.
Main goal is some tunes for long drives, and be able to hit the drive in!
I initially went with a pair of 5 1/2" speakers under the seat facing forward. Sound was decent with more than enough volume capability, but it was lacking in sound quality. I didn't have the expectation of a dedicated sub kind of bass but wanted a bit more than the pair of speakers provided. I moved the 5 1/2" pair to the kick panels and mounted a pair of 6x9's under the seat. After insulating the cab and putting carpet on the floor, It sounds better than the stock system in my '07 F150.
bc4x4f250
1961 - 1963 F100 Unibody
05-29-2018 07:32 PM
boboh1
05-23-2012 08:05 AM
matt2491
13
02-15-2009 07:03 PM
