Please help! Emergency, far from home, battery light
Hello everybody,
Currently racing down to the Bay Area to a family emergency in our 2001 f250, 7.3 4x4. As we were driving down the highway, 75 mph or so, the battery light came on. We pulled over, tightened the battery terminals and began driving again. The light returned again. Stays solid for a bit, flickers, goes away, then comes back solid. Ammeter on the dash reads just past the middle on the higher side, regardless of the light being on or not. Please help, this is a life or death situation and we have to make it there. Thank you very much in advance.
Step one of just about every repair is "remove negative battery terminal cable". I've been surprised in the past with how little visible dirt can cause a problem. I know you said you tightened em, but I'd take em off and really get int here good and make a good connection. If you have jumper cables, you can run one from the negative terminal to ground, and if the light goes away, then that cable is your problem at some point. Since the light has been somewhat intermittent then I'm more likely to believe a ground wire issue than a component issue.
