1995-1997 7.3 help please
Hello all,
I am restoring a 97 f350 and have been swapping many parts/components.
So, this is what I idid and this/these are my issues I need help with.
Thanks in advance
engine 1995
engine wire harness 1997
cab 1997 (automatic)
engine compartment harness 1997
pcm (1995 manual)
issues:
starts, and idles only
no throttle at all
cel on
blows fuse #3 (wiper) instantly
My research shows all harness are identical however
I found that there is a difference at he wiring in the plug that goes to the transmission (manual)
also found a small difference in the connector at the icp
Anyone?
Thanks in advance
engine 1995
pcm (1995 manual)
issues:
no throttle at all
cel on
Anyone?
On the IVS there should be 12 volts on the brown wire with key ON. Pressing on the throttle you should have 12 volts on the other wire, Red/Org. If so the IVS is working. Fuse #2 only controls the wiper circuits so that is not the issue. Still sounds like a IVS issue so check the voltages to eliminate it.
1995-1997 ENGINE BAY WIRE HARNESS DIFFERENCES
HELLO,
I was having an issue with a 7.3 that would run, but no throttle.
I searched high and low to find out if there were any wiring harness differences between 95 and 97. and everywhere says they are all the same
WELL THEY ARE NOT!!!!
here is what I found after many hours doing pin tp pin etc.
what I had :
1997 cab
1995 engine
1997 engine harness
1995 pcm
1995 idm
With a 1994.5 eng compartment harness
- no start with key
- idle only/no throttle
- long cranking to start
- cel on
(note harness plug has visably less wires)
With a 1995 eng compartment harness
- starts with key
- long start time
- idle only no throttle
- cel on
- blows #2 wiper (30a) when key is turned on
With a 1997 eng harness
- stars quick
- no cel on
-throttle works
So ...I hope this will help someone sometime
with
what I had :
1997 cab
1995 engine
1997 engine harness
1995 pcm
1995 idm
- no start with key
- cel on
- starts with key
- long start time
- cel on
- stars quick
- no cel on
-throttle works
with
fordka
05-02-2019 01:09 PM
DasCheckers
WTB - Parts & other
11-14-2016 08:07 AM
F250GH
01-25-2009 09:08 PM
Woodlums
10-04-2005 08:57 PM
