Have a code Po3o4 Cyl 4 misfire. I pulled the valve cover to remove the injector and found the right half of the rocker mount and rocker arm laying in the head. Any ideas as to what may have happened?
I was driving when it picked up a shutter in overdrive. Brought it home and parked it. Hooked it up to the computer and got the code. Thought it was a bad injector so I started taking it apart and found the broken rocker.
