bent push rod?
Old Feb 12, 2013 | 12:14 PM
austinlittle34's Avatar
austinlittle34
bent push rod?
hey guys i just got the valve cover off my 4.9 and had a lot of rocker play and the rocker was torqued to specs so i tried to pull the push roud out the top of the head and wont come out so does this mean the pushrod is bent ?
Old Feb 12, 2013 | 12:47 PM
F150xlt's Avatar
F150xlt
That's a strange one. If the rocker arm is torqued down the
only way you could get play in the push rod is if the lifter
collapsed, the valve is stuck open, a broken valve
spring or the push rod failed from over revving.
To replace a hydraulic lifter you can get to it by removing the
push rod tube cover on the driver side of the engine.
Old Feb 12, 2013 | 02:23 PM
blue924.9's Avatar
blue924.9
i would bet overrev it seems to be wayyyy to easy to do with a 4.9 especially if you dont have a tach
Old Feb 12, 2013 | 04:28 PM
austinlittle34
it was a bent push rod its almost bent in an S the lifter seized up
huntke
Apr 9, 2012 02:10 PM
jcahicks
17
Mar 8, 2011 09:51 PM
Blade79
Maryland Chapter
31
Aug 13, 2010 05:56 PM
NW 150
19
Aug 9, 2010 09:09 PM
canister
Feb 20, 2010 05:32 PM
