1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Fuel Filter Water Separator Freezing Question
Old 01-18-2016, 05:02 PM
littleapple's Avatar
littleapple
littleapple is offline
Ok, this is probably a stupid question. We have been having near zero temps for several days and it occurred to me that there may be some amount of water in the water separator in the rail mounted fuel filter (not enough to send a message, but maybe some amount). I only have 3,000 miles on the truck. So, just wondering if a small amount of water is going to hurt anything in the filter or filter housing if it freezes? Should I drain the filter in freezing weather even though enough water hasn't collected enough to activate a message? Thanks for your replies.
Old 01-18-2016, 05:21 PM
4jfarmer's Avatar
4jfarmer
4jfarmer is offline
I wouldn't think it will be a problem but if cocerned,add some sea foam to your fuel system. Helps remove moisture from fuel and cleans the fuel system. I use it on my vechiles,tractors and small engines. There's other brand names additives but this is the only one I'm familiar with that has served me well.
Old 01-18-2016, 06:48 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
I would say this concern is really a non-issue if you drain the separator every oil change, which is normal.
That said, Seafoam can be up to 25% isopropanol. I would NOT run any alcohol through a common rail diesel. No offense, a diesel in a tractor or a small engine is very different from a common rail diesel where fuel pressure get's crazy high compared to HEUI and mechanically injected diesels.
Originally Posted by Form 6.7L Diesel Fuel System Contamination Diagnosis and Service Procedure Job Aid
Q. What are the effects of non-recommended fuel additives?
A. Alcohol based additives or other chemicals that cause water to disperse/emulsify will cause damage to the fuel system. Chemicals that disperse/emulsify the water in the fuel will not allow the filters to properly separate the water and pass it through to the fuel system. Alcohol based additives also decrease the lubricity of the fuel, which can damage the high pressure fuel system.
Contaminant:
Incorrect Fuel Additives - (alcohol based and other)
Symptom:
Low fuel pressure on HP and/or LP side, poor driveability
Effect:
Premature HP pump and fuel injector wear, may have rust/corrosion, or only debris
Indicator:
Rust/Corrosion if water emulsifies and prevents fuel, water separation
http://www2.apwa.net//Documents/Abou...re_Job_Aid.pdf
Old 01-19-2016, 07:55 AM
Desert Don's Avatar
Desert Don
Desert Don is online now
Received 4,709 Likes on 1,669 Posts
Drain the filter bowl monthly into a glass jar, let it set for 10 or 15 minutes, examine it for any water/contaminants and as long as the fuel is clear, there is no water/contaminants to worry about! As long as you are buying fuel from hgh volume, reputable fuel sources, you should not have any problems.
Old 01-19-2016, 08:30 AM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
you'll be fine unless you have a ton of water in your fuel, in which case you'll have more problems to worry about then the separator freezing.
Old 01-19-2016, 09:04 AM
donovan's Avatar
donovan
donovan is offline
NO Seafoam for Newer Diesel
Second on NOT using seafoam.
I have been running diesel since 2008 and still have not seen any water in fuel. But you should still drain it once a month. You could pull a sample after the truck has ran for a bit or when its above 32 degrees for a day or so. Saying that I spend most of my time in SOCAL.
Old 01-19-2016, 09:56 AM
DJRAAL's Avatar
DJRAAL
DJRAAL is offline
You should be alright a small amount of water freezing would just displace the fuel in the filter. Fuel additive would be your best best in the winter
90pioneer
11-03-2013 08:23 PM
96_F250_Deezal
11-11-2012 09:25 AM
jshumadine
6.4L Power Stroke Diesel
03-04-2008 06:45 AM
dunbar15
01-15-2006 09:23 PM
jmbatlanta
05-02-2003 08:35 PM
Quick Reply: Fuel Filter Water Separator Freezing Question
