6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fuel Filter Drain Question
Old Mar 3, 2008 | 09:24 AM
jshumadine's Avatar
jshumadine
How often do you guys empty the fuel filter that is under the truck on the frame and how long does it take you? Are you finding water in your fuel?
Old Mar 3, 2008 | 12:05 PM
66stang351's Avatar
66stang351
I hope nobody "empties" it. Just open it long enough for any water to drain out then close it back up. I cracked it open at 10,000 miles and got maybe 2 drops of water then fuel. I had it open a total of about 3 seconds and had pure fuel for most of that time. The quality of your fuel and to a lesser extent the relative humidity where you live should probably drive how often you check it. I plan on every 10,000 miles just because it is easy to remember. Also, if I think I might have got some bad fuel I'll check it.
Old Mar 3, 2008 | 01:40 PM
ab257z's Avatar
ab257z
I just checked it at 3,000 miles - no water at all.
Old Mar 3, 2008 | 03:07 PM
SaharaF350's Avatar
SaharaF350
I check every 10k when I'm changing the fuel filters. So far so good, haven't really seen any water.
Old Mar 3, 2008 | 03:59 PM
NJF350SD's Avatar
NJF350SD
Doesn't the manual indicate or reccommend a monthly drain? Is this not the case?
Old Mar 3, 2008 | 07:07 PM
RangerEdgeO2's Avatar
RangerEdgeO2
It does recommend a monthly drain mianly b/c fuel quality varies between stations. Diesel that has been sitting for a long time will have more water in it.
I have had my truck since August and drained it two times. Last time i got 2 drops, if that, out of it. I have never had the light come on telling me to drian it.
Old Mar 3, 2008 | 09:53 PM
stroke this's Avatar
stroke this
I have checked mine Twice at 10 and 15,000 and no water. I would keep a check on it and change as needed if you are finding water.
Old Mar 4, 2008 | 06:45 AM
jrc55's Avatar
jrc55
While we're on the subject, how much do you need to drain out to lower the level in the filter on the engine so when you take the top off to change the filter, fuel won't overflow and make a mess? Also, will draining that much at the frame mounted filter cut down the spillage that will run down the frame and your arm when changing the lower filter? Thanks, inquiring minds would like to know.
brazoriastang
2004 - 2008 F150
Aug 3, 2009 06:18 AM
1Knight
Dec 23, 2005 03:41 AM
AV3Fire
Sep 16, 2004 10:04 PM
joefran
1983 - 2012 Ranger & B-Series
Aug 2, 2004 07:49 PM
Stampede
Feb 7, 2004 04:02 PM
