No oil pressure on cold start?
A few times recently when I start up my 89' 302, on a below freezing morning, the engine fires up as always but the oil pressure gauge doesn't budge. There is no change in sound or idle to the engine. After a couple minutes I shut down and restart then the gauge functions fine.
My question is if the cold could affect the gauge/wiring or is it likely a mechanical issue? How would I test other than running a mechanical gauge?
Glad to hear it's likely the gauge. I figure other than a complete mechanical failure with the oil pump drive shaft or oil passage obstruction (unlikely), it's just a tire gauge/wiring.
Mechanical gauge will go in with my donor for just this situation.
Off-hand i believe I'm running 5W, whichever is required. You reccomend anything particulate for cold NE Ohio winters?
Grunter
11-05-2005 01:58 PM
