49 F1 Heater motor
I did a lot of research online, found one from one of the F1 parts dealers, but they were asking well over $100. Finally found one online for $30, but when it arrived it didn't match the dimensions on the datasheet, and therefore didn't fit, so I returned it. Finally gave in and spent $50 at NAPA. I bought a complete add on fan assembly, removed all the stuff from the motor, and it fit like a glove. I think they have a cheaper version online, I bought the only one they had, which was chrome, and you obviously don't need chrome.
Which heater do you have? Is it a ford script or something else? You might be able to find a proper replacement here:
Heater Motors, Pumps, & Parts - Heater Motors - Unity School Bus Parts
If you are talking about the three-door heater, that looks similar to this:
I replaced the motor with a MEI 3354. It's a single speed reversible motor.
Blower Motor, 3354, Airsource
Ross is right, just swap the power leads. Here is where I got mine:
Blower Motors - School Bus Parts - A Parts Warehouse
The people are most helpful if you have a question.
But it all depends upon which switch that you have. I have seen blowers switches that have resistance built in. Usually you can see the resistor coil from the back on the older switches that are variable speed. A contact rubs across the coil changing the resistance value. I'm not sure that I would use one of those if I was changing from 6v to 12v. Maybe somebody else has a better opinion about that.
joezzz
11-29-2012 10:09 PM
HT32BSX115
09-24-2005 10:18 PM
