oil in exhaust and leaking out dipstick
Old 12-23-2015, 01:32 AM
joeruger509's Avatar
joeruger509
joeruger509 is offline
My neighbors 95 PSD started leaking out the dipstick and he noticed oil residue in the exhaust. Any ideas before it goes to the shop???
Old 12-23-2015, 05:29 AM
fordpride's Avatar
fordpride
fordpride is offline
The top of the dipstick or where it mounts to the pan ?
Oil in the exhaust is an indication that the turbo needs a rebuild.
Old 12-23-2015, 07:59 AM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
Tell your friend to in list to FTE before he heads to the shop, so he can go with some knowledge into the shop, or he can fix himself
Oil in the tail pipe is indication of a bad oil seal on the turbo, oil coming out the dip stick might just be the o ring the disp sticks have, check how much blow by the engine has,(with engine flip oil cab up side down on the fill hole and see it gets blown off if so, not good. Unless the dog house is plugged up( driver side valve cover the housing on it take it out clean it with some gasoline dry it put it back in.
Old 12-23-2015, 06:56 PM
joeruger509
I'll ask him tonight where it leaks he is an older guy who is not internet savvy. So he wouldn't know how to use the forum's.
Old 12-23-2015, 07:55 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Make sure it is oil residue in the exhaust, and not just suit and condensation mixture. A lot of people who are not familiar with the diesels make that mistake.
Old 12-23-2015, 10:56 PM
joeruger509
So it's blowing the dipstick out. Bad piston maybe?
Old 12-23-2015, 11:10 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
That would be excessive blow by for sure. Take the oil filler cap off and turn it upside down over the hole while the engine is running,and see if it blows it off the hole.
Old 12-23-2015, 11:47 PM
fordpride's Avatar
fordpride
Could also be a clogged ccv which would also explain oil in the tailpipe
Old 12-25-2015, 02:54 AM
joeruger509
Where is his ccv is it cleanable or just buy a new one.
Old 12-25-2015, 09:05 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Its on the top back of drivers side valve cover held on by two bolts. The wire screen is cleanable.
komida
09-28-2017 01:11 PM
Amnfoxtrot
06-19-2013 08:52 AM
parkland
6.4L Power Stroke Diesel
03-04-2012 01:03 PM
randomhero1172
18
04-11-2008 08:32 AM
88B_RONC
10-11-2003 11:06 AM
Quick Reply: oil in exhaust and leaking out dipstick
